Gosmeta
Manuals and Catalogues
Print code: G166
GOSMETA Full-range Machine Tool catalogue 1960s. Shows the full range of Lathes (Centre, Toolroom, Capstan), Eccentric Presses, Milling machines, Presses, Shears/Guillotines, Press Brakes, Plate Benders, Nibblers, Chucks, Toolposts, Dividing Heads, Rotary Tables, Bench and Pillar Drill Presses, Radial-arm Drills, Hacksaws, Bandsaws, Circular Saws, Carbide Tool & Twist Drills Grinders, Surface Grinders, Horizontal Borers, Shapers and Welders. Text in English, French, German, Italian and Spanish. 106 Pages.
Print code: G166A
GOSMETA Lathes Types D-135, D-180, D-220, D-310A, D-310B and D-410. Sales & Specification Catalogue. 6 pages.
Print code: G166B
Gosmeta Inclinable Presses Models EPS-30, EPS-40, EPSR-40, EPS-60, EPS-60, EPSR-60, EPSR-80 and EPSR-100. Sales & Technical Specification catalogue. 4 pages with an electrical schematic
Print code: G166C
Gosmeta Straight Back Eccentric Presses Models EP-6, EP13, EP-25, EP-40, EP-60, EP-80, EP-100. EP-120 and EP-150. Detailed Sales & Technical Specification Catalogue with full data about the machines' capacities, construction and functions.Includes cutaway drawings. 14 pages.
Print code: MG700
Gosmeta Press Brake KM. Operator's Instruction Manual.
Print code: MG701
Gosmeta D135 Lathe (appears identical to the Gromatic 140 and the manual is for that machine ). Operation & Maintenance Manual with useful Sectional Drawings and Electrical Schematics. The lathe shown has two separate levers on the front of the stand to change the spindle speeds. The Gromatic with the two levers mounted on a common shaft is otherwise identical. While perfectly readable, this manual is not to our usual very high standards of reproduction.
Print code: MG915
Gromatic 140 Lathe (appears identical to the Gosmeta 135). Operation & Maintenance Manual with useful Sectional Drawings and Electrical Schematics. The lathe shown has two separate levers on the front of the stand to change the spindle speeds. The Gromatic with the two levers mounted on a common shaft is otherwise identical. While perfectly readable, this manual is not to our usual very high standards of reproduction.
