Strips of the correct density felt (made in Germany) that can be cut and packed into the holders: each strip is 150 mm long, 10 mm wide and 8.5 mm deep which is usually enough to make a set of bed-wiper for a lathe or other machine tool. The felt often be cut down to act as a wick of the type used to lubricate some types of plain bearings.
£8.00
