Drive belts for the vertical milling head fitted to Toyo (Manix) Record ML210 lathes (or the stand-alone milling machine version). The belts are top-quality, Swiss-made Polycord in the special machine-tool drive variety. Two belts are supplied in the set with lengths of 265mm and 285mm.
Belts for the Toyo (Manix) Record ML210 lathe can be found here: https://store.lathes.co.uk/parts/toyo-manix-ml210-lathe-belts
£24.00
