Emcomat 7 and 7L lathes: Toothed Drive Belt. Only the 3/4" (19 mm) wide belt is now available. The 1-inch (25mm) belt is no longer made. If you lathe has the wider belt,. the narrower one will still work but, if the lathe is hard used, will not last as long.
£39.00
