Rack-pinion gear for the Raglan "5-Inch" lathe - the gear that engages with the bed-mounted rack. This gear has a double-diameter shaft and will only fit the later Raglan 5-inch lathe and not the "Little John" If you are uncertain about which lathe you have, a picture of the "5-inch" is here and one of the "Little John" here. If you need a rack-pinion gear for either the Raglan Little John Mk.1 and Mk.2 it can be ordered here
£78.00
