Arundel J4 senior wood lathe. This was my father's lathe - I know little about it - but it is a very strongly built, heavy lathe with a good reputation. It has a chuck and is fitted with a bowl-turning attachment.Single-phase motor with a sto-start button switch (which sometimes sticks) and the cable to it will need replacing. Can only be collected at weekends due to working away. Details of these lathes can be found here: http://www.lathes.co.uk/arundel
For Sale & Wanted
Welcome to our classified adverts pages. If you'd like to advertise a machine or accessories here, or would like to place a Wanted advert, click one of the buttons below. You'll need to be logged in first; If you don't yet have an account with us, you will be asked for an email address.
Wanted: Parts for a South Bend 9-inch (or Boxford or Smart & Brown "Sable" Lathe). I would like a saddle, a tailstock base (or a complete tailstock) and a 54-inch long bed. Would also consider a complete South Bend 9-inch lathe. Thank you, Spiros. I am in Greece - but I have a contact in the UK for delivery. The parts that I need are for a lathe like this: https://www.lathes.co.uk/southbend9-inch/img0.gif
Myford Super 7 lathe. Mounted on the maker's cabinet stand with a deep chip tray and levelling blocks. Single-phase motor and a Dewhurst reversing switch.
Raglan Little John Mk.2 variable-speed lathe. 5” inch centre height and 24” between centres. Fitted with a screwcutting gearbox, power cross feed and a single-phase motor. Complete with a 3-jaw chuck, quick-change toolpost with one holder, faceplate, tailstock chuck, thread-dial indicator and a digital speed readout. The variable-speed drive belt has recently been replaced. The wooden cabinet is not included, Full details of these strong but compact lathes here: http://www.lathes.co.uk/raglan
Lorch LAS model 2.5" x 11.25" miniature precision backgeared and screwcutting lathe in good used condition.
Wanted, for my just-purchased ManSon lathe, the maker's boxed accessory kit. Or, any parts from such a kit. Details of ManSon Accessory kits can be found here: https://www.lathes.co.uk/mansonaccessories/
Pinnacle Milling and Co-ordinate Drilling Machine. Table 730mm x 210mm with inch micrometer dial graduations. The quill had both a find-feed by a handwheel and a rapid-action handle for drilling - the MT3 taper spindle allows easy transfer of tools from a lathe. 12 spindle speeds from 100 to 2050 r.p.m.
Cowells 90ME Precision Miniature Lathe, backgeared for slow speeds and screwcutting. Mounted on the maker's cabinet stand, the lathe is in very good condition, exceptionally well equipped and with a range of genuine maker's accessories including a milling slide, a Burnerd precision ring-scroll 3-jaw chuck, a set of collets and collet holder, fixed steady, faceplate, machine vice, range plate, a rear toolpost for parting off, tailstock chuck, and a "wobble" centre finder. Single phase electrics.
Transwave 1-phase to 3-phase 1.8 kW (2.4 h.p.) converter. Little used and in perfect order. £375 (current price over £700)
Burnerd Multi-size Chuck on a Camlock D1-3 spindle fitting with the boxed set of collets. Capacity 1/8" to 1.5". Each collet is adjustable over a range and so will take both metric and inch sizes. £450
A Pittler C3 Classic Lathe with an extra long bed and an overhead drive system with its own 1-phase motor.This is an early model, Serial No. 890, very well equipped and in full working order. Extras include 3 and 4-jaw chucks, a quick-withdrawal mechanism on the top slide to ease screwcutting, a ball-turning attachment, a tailstock that sets over for taper turning and a spindle with a headstock spindle thread. 25 worms and wormwheels for screwcutting, both the standard ‘forked’ and retracting toolposts and a tailstock chuck. 1-phase motor and a Dewhurst reversing switch.
Excel Vertical Milling & Co-ordinate Drilling Machine with an R8 Bridgeport-type spindle that gives access to a wide range of inexpensive fittings. The quill has both a fine feed through a handwheel and quick-action drilling by a capstan handwheel. In superb condition, mounted on a floor stand and with single-phase electrics.
Robland-Startrite Model SD310 is an Industrial-class wood planing machine.
Feed speed 7m/min.
Cutter block speed 5300 r.p.m.
Cutter block diameter 70 mm.
Max thickness capacity 305 x 200 mm.
Max planing width 320 mm.
Max depth of cut thicknesser 4 mm.
Max depth of cut planer 3 mm.
Fence tilting angle 45 degrees. In excellent original condition and mounted on casters for ease of movement. Single-phase electrics. £650 or offers
Myford ML7 Lathe 3.5" x 20" backgeared and screwcutting and mounted on the maker's stand with chip tray and levelling blocks. The lathe is in its maker's paint and the front way still shows evidence of the original machining marks.
Myford ML7B 3.5" x 20" fitted with a screwcutting gearbox, spindle clutch, 3-jaw chuck, 4-jaw chuck, dial-thread indicator, tailstock chucks, tailstock rotating centre, 4-way toolpost. Single-phase motor with a Dewhurst reversing switch. The lathe has stood unused for some time and, although it needs a good clean, it includes a huge range of equipment and tooling - all shown in the comprehensive set of photographs. £950 or offers.
Cowells 90ME Miniature Lathe backgeared and screwcutting model engineering lathe - mounted on a small cabinet with storage drawers. 1.75-inch centre height, 8 inches between centres gap bed and 12 speeds spanning 60 to 2100 r.p.m. The cross slide is extra-long and T-slotted, the top slide swivels and the carriage feed incorporates an adjustable, automatic disengage mechanism. Single-phase motor, the correct 3-jaw chuck, faceplate, tailstock chuck, a hand T-rest, Morse centres and a copy of the maker's Instruction manual.
Hazdent Heavy Duty Spinning Lathe - with parts that enable it to turn wood. The photographs show the lathe dismantled for moving - it comes apart very easily - but on this page are pictures of the same model assembled and with details of the Hazdent Company.
Jones & Shipman 540H Surface Grinder. This high-quality, compact grinder is a very unusual version, one with all hand feeds. An ex-college machine and so very lightly used. Complete with a magnetic chuck, two spare grinding wheels and a 3-phase motor (that could be easily changed). £950 or offers. Full details of the Jones & Shipman 540 grinder here
Elliott 10M Shaper. An ex-college machine in lightly-used condition. A compact shaper ideal for the smaller workshop and complete with a swivel-base machine vice.. £650 or offers. Full details and a specification sheet for the Elliott 10M can be found here
Deckel SO bench-mounted Tool & Cutter Grinder. A top-quality machine in full working order and lightly used. Complete with a set of 35 collets, the maker's tools, two spare grinding wheels and two drive belts. Single-phase motor. Full details of Deckel SO tool & cutter grinders here.
Deckel G1-L Pantograph Engraver. The "L" stands for "large" a model with an increased capacity. In lovely condition and full working order with a single-phase motor, 12 drawers of typeface (in a set of drawers), a set of collets, table clamps and the maker's instruction book. Details of Deckel G1-L engravers here - and the last picture below. £550, or offers.
For Sale: a late-model Edgwick Mk.1 lathe in full working order and as used by me in my classic car restoration business (Carlow Engineering TR Specialists).Complete with chucks, faceplate, tooling and a 4-way toolpost. This is an urgent sale - so just £495 or offers. I also have an old but fully functional Pollard "Swan-neck" drill that is included. Full details of Edwick Mk.1 lathes here
Wanted: Myford Drummond M-type Lathe. Anything considered so long as it’s in working order. Private buyer. Phone: 01584-711730 or 07913-849868 Lathes like this can be seen here
BCA Mk.3 Precision Jig Borer/Miller in exceptionally fine condition an unusually well equipped. Mounted on the maker's cabinet stand with cupboard and drawer storage (the drawer key is present) and owned by me for the past 35 years and used only for light-duty clock making and model engineering. Fitted with a variable-speed inverter than runs quietly and provides a very wide range of spindle speeds the increases the span of the normal 300 to 3250 r.p.m.
I now have my own workshop that I can fit a lathe in - and I'm ready to buy.
I'm looking for a small lathe capable of metric threading, hopefully with a lot of accessories included to save some effort tooling myself up, so I can get stuck in straight away with the learning. Ideally, a belt-drive lathe which I will power from a 3-phase inverter. I will struggle to move the lathe, as I don't drive, so local to me in Glasgow is ideal.
This Ward 2A Capstan Lathe is an old but useful machine in very good working order. It was used regularly in my engineering business and, more recently, in my retired workshop With the lathe are many of the essential Ward accessories including roller boxes, collets, chucks, etc. The catalogue extracts below give the lathe's full specification. Please contact me on 07968-808353 for further information. I also have many additional engineering items for sale as well.
A pair of unused André Bechler Swiss "Simplex" Gear and Pinion Engines. Priced for sale as a pair - but would split. The two machines were originally obtained still with their manufacturer's packing grease. One was commissioned by having a professionally-made motorised stand made, with pulleys and electrical equipment to run it. That machine was cleaned and overhauled in preparation for the semi-automated production of horological (watch) pinions. The second machine still has all its protective grease in place.
Myford ML7 Lathe 3.5" x 20" gap-bed, backgeared and screwcutting. Included are many useful accessories and a range of associated tooling - all collected over many years and shown in the photographs. £1775 - offers invited.
Myford ML7RB lathe 3.5" x 19". The ML7RB is, in effect, a Super 7 less the clutch unit. Fitted with a screwcutting gearbox and mounted on a good metal stand with a tool tray, levelling blocks, chip tray and a light unit. In superb, lightly-used condition, this example has had just two careful owners from new in 1982/83.
Drummond Round Bed Lathe - a classic very early model with bronze cap spindle bearings. In fine original condition and complete with the maker's treadle-type foot motor, a period 3-jaw chuck, Drummond angle plate, faceplate, tailstock chuck, Morse centres and a full set of screwcutting changewheels and their correct mounting studs. £350 or offers. Full details of these interesting lathes here
Amolco Vertical Miller. This is the complete, stand-alone unit - and seldom found as it was so expensive new. Very compact, fitted with a single-phase motor and a No.2 Morse taper spindle that also has a standard Myford thread to mount chucks and other fittings. In lovely condition and ready to use - my only reason for selling is that I now have a larger miller. Details of these millers here
Victoria Elliott Horizontal Milling Machine. 3-phase with some tooling. £350 or any offers considered.
Startrite 20RF Vertical Bandsaw. A powerful, 3-wheel model with a 1.5 h.p. 3-phase motor, a 20-inch throat and weighing 363 kg. Currently in use.
Antique Norton Hand-operated Surface Grinder, 3-phase. Complete and original. £350
Hand-operated rollers £250
Heavy, treadle-operated shears. £350
Kondia Powermill Vertical Turret mill. Fitted with the variable-speed head, a 3-axis DRO and complete with a good quality machine vice, a light unit and some tooling. 3-phase electrics.
Colchester Mascot 1600 Lathe. 3-phase. Fitted with a 3-jaw chuck, a Dickson quick-set tool post, a rear tool post with a second quick-set Dickson toolpost, a standard faceplate, a large faceplate to run in the gap, fixed steady and coolant. Full specification details in the pictures below below.
Fobco 7/8 "backgeared" pillar drill with 10 speeds from 51 to 2650 r.p.m. A heavy-duty drill with a reputation for reliability. 3-phase electrics. Full technical specifications in the pictures. £600
Norton No.66 Fly Press. £500
Colchester Master 2500 Lathe. 6.5" x 30" with a hardened bed, spindle clutch, coolant, a full-length splashback to the stand and a top speed of 2500 r.p.m. It appears to be sound - and as the deceased owner last operated it. Accessories include: a quick-set toolpost with 6 tool holders, the correct 4-jaw independent chuck, a multi-position rotating carriage stop, light unit, thread-dial indicator, a tailstock rotating centre, a faceplate and a chuck guard.
Antique Milnes Lathe with Ornamental Turning Attachments 4.5" x 30" gap-bed, backgeared and screwcutting and with power cross feed. One-family ownership from new - my great-grandfather bought it - and in beautiful condition. Complete on the maker's treadle stand and fitted with the correct "overhead" to drive toolpost-mounted high-speed grinding and milling spindles. In addition to the treadle drive, a well-engineered electric drive is fitted (though I have only ever used the treadle and never tried the electric - so I cannot comment on its state).
Boxford BUD lathe 4.5" x16" Mk.2 with single-lever engagement of backgear. An all-metric machine on the maker's compact underdrive stand (just 45 inches long) on castors for ease of movement and fitted with power cross feed, a T-slotted cross slide, a new 1 h.p. single-phase motor, rewired (wiring diagram supplied) and all-new V-belts including the link belt to the spindle. Serial number DEM 8656/1/38 (probably 1977) and purchased 2010 direct from a school. It still has the maintenance sticker from Bowerhill (tel. 01225 705 321) dated "2/12/10, next service due – 8/12/11".
Manchester Rapidor Hacksaw. A low-hours, late-model, ex-university machine with the speed-reduction gearbox built into the motor. Fitted with coolant amd in full working order. 3-phase motor. £450 or offers. Details of Manchester Rapidor hacksaws here
Meddings Type F14 Pillar Drill with backgear. The F.14 is the top-of-the-range version of this high-quality drill with a solid column and the articulated, swing head - the latter, combined with the rotating table, allows a great variety of work to be undertaken. The low-speed backgear to the head combined with the direct V-belt drive provides eight speeds from 80 to 1500 r.p.m. Rack and pinion rise to the 20" x 20" T-slotted table. An ex-university machine, little used from new and in superb condition and perfect working order. A high-quality machine vice is included.
Holbrook Edgar Lathe - a superb example of this high-class antique, swing-bed lathe. Fully restored and in lovely condition. All the beds have been professionally re-scraped by hand and the bearings are in excellent condition. The lathe can be powered by treadle but has all the overhead gearing and a motor with new bearings fitted.
Potter Precision plain-turning bench lathe 3.6" x 16" - probably catalogued as the "No.5". Complete with a countershaft unit, single-phase motor with push-button starter, screw-feed compound slide rest, 3-jaw chuck, a 6-inch independent 4-jaw chuck, faceplate, and a catchplate. Stored unused for many years, it needs a good clean £250 or offers. Full details of Potter precision lathes here
Enbeeco 3-axis Binocular Collimator manufactured by Newbold and Bulford in London. this 3-axis unit takes the axle into consideration and allows collimation at every position of the IPD. In full working order. £250
Powerful V-twin 1-phase compressor. £125 or offers
Carstens/Swiston Lathe and Ajax Mini Drill. The "Swiston" is a German-made machine around 4" x 20" with backgear and screwcutting. Complete with a good 6-speed belt-drive countershaft that, together with backgear, provides 12 spindle speeds. 4-way toolpost, 3-jaw chuck, a precision keyless tailstock chuck and a large collection of screwcutting changewheels. Single-phase motor. £375 or offers. Details of Carstens/Swisten lathes here
Warco WM18 Vertical Miller - an excellent specification and an all-geared head. Fitted with a 3-axis DRO on the table and main head travel - and with an independent DRO on the quill feed. The spindle taper is an R8 (giving access to inexpensive Bridgeport tooling) and runs in taper roller bearings. The head tilts 90 degrees on each side of the vertical and the quill has 70 mm of travel by both a fine-feed by handwheel and a rack-and-pinion quick-lever feed for drilling.
SIP SP-4 Jig borer / milling machine. When bought, this fine jig borer had been converted to a coordinate measuring machine but is now back to its original function using a Warco ZX-15 3 Morse spindle. No modifications were necessary to the borer save for the removal of the measuring probes holder (which is supplied) and using the original bolt holes to carry the head on the cross beam saddle. The 19" x 27" T-slotted table is unblemished, and a longitudinal travel of around 25“.
Harrison L5A Lathe 5.5" x 24" with an induction-hardened bed with a detachable gap piece, a full screwcutting gearbox with 36 changes of threads and feeds, power cross feed and a spindle clutch. This is an ex-education machine maintained in full working order. Fitted with a top-quality Newton-Tesla Mitsubishi variable-speed inverter running from a household 1-phase supply. The inverter gives both higher and lower speeds than the standard 40 to 1000 r.p.m.
Boxford AUD Mk. 2 lathe Serial 16580 4.5" x 21" and manufactured 1964/5. 1-phase. Mounted on the maker's compact underdrive stand just 45” x 18” overall with a splashback. Bought November 2004 through this site, from an engineer in whose hobby was making clocks. I've used it for motorcycle restoration and workshop components. It was well equipped but I have added such as a rear tool post, a Bison chuck and steadies, etc. Metric dials, but an Imperial lead screw. Gearbox set for British threads with a metric transposing 100/127t changewheel included.
Myford Super 7B lathe 3.5” x 19” gap-bed with a screwcutting gearbox, power cross feed, hardened bedways, mounted on the maker’s industrial cabinet stand and driven by an expensive Newton-Tesla infinitely-variable speed drive.
Syil X4 Plus CNC milling machine with Masso CNC controller and monitor. Bought new by me for light hobby use only in my heated workshop. The miller is fully functional and has proven to be very reliable - needing just one air strut for the Z axis in the years I've owned it. It is possible to control the machine using a PC and Mach3 rather than the Masso controller if preferred. This is a robust light industrial machine, a model that has acquired a good reputation in recent years.
Basic machine specs:
Cuttermaster MG-30 Tool & Cutter Grinder with Attachments and Accessories. Serial No. 5474 and bought new by me from Brierley Grinders. Very light hobby use in my heated workshop. Specifications: Air Bearing Stroke: 9.5”. Cutting Tool Cap. Shank 1", Cutting Tool Cap., O.D. 3", Max. flute Length 9". X-axis table travel 6". Y-axis travel 3" plus a motor slide of 6". X-axis working space 16.5" x 5.5". Y-axis working space 13" x 5.5". Grinding wheels 5" cup or 6" dish with various arbors included. Motor head tilt +35/-8 degrees.
Boxford STS 10.20 Geared-head all-metric Lathe with a screwcutting and feeds gearbox and power cross feed. Centre height 132 mm and admitting 500 mm between centres (5.2" x 20") with a spindle bore of 35 mm (1.375"). An ex-education machine running on an infinitely variable speed 1-phase to 3-phase inverter. The original spindle speed range was 40 to 2240 r.p.m. but the inverter expands this to higher and lower r.p.m. The lathe is in really good condition with no chips or gouges in the bed, nor any wear marks - although some staining is visible in the photos.
Myford Connoisseur Super 7B "Big Bore" Lathe 3.5" x 19". This is the final and top-of-the-range version of the Super 7. Fitted with infinitely variable-speed drive, 1-inch bore spindle, a screwcutting gearbox, power cross feed and mounted on the maker's cabinet stand. I have had this lathe from new, used it only for light hobby work and kept it in my heated home workshop.
Cowells 90ME Precision Miniature Lathe. One owner from new and in perfect working order. Backgeared, screwcutting and well equipped with a collet set, milling slide, ring-scroll 3-jaw chuck, quick-set toolpost, fixed steady, travelling steady, a G.F.C.Watts quartering jig, large and small tailstock chucks, tailstock V-pad, V-block with clamp, a set of turning tools, and spare drive belts. Details of Cowells 90 lathes here
Emco Emcomat 7 machining centre - an Emco 7 lathe complete with the 4-speed vertical milling head. This compact and versatile assembly has 3.5" (90 mm) centre height and 17.5" (450 mm) between centres. Two very useful features are the excellent spread of speeds - 65 to 2800 r.p.m. - and the ease of changing them. There no belts to move, only two headstock-mounted levers and the 2-speed, 1-phase electric motor push buttons. The 4-speed vertical head is self-contained with its own motor and control from push buttons on the headstock.
A collection of micrometers, height gauges, calipers, magnetic base, dial indicator and associated items. Offers invited
Harrison vertical and horizontal "universal" milling machine. This is a rare, top-of-the-range example equipped with all the options: a swivelling "universal" table, power-feed to the table, a clutch to the spindle drive, "step-up" vertical head, a vertical and horizontal rotary table fitted with a 3-jaw chuck, coolant, Low-Vo light unit and swivel-base and standard machine vices. This is a workshop clearance and there may be a quantity of tooling included as well. 3-phase electrics.
Hayes Diemaster precision vertical milling machine Type 21a Serial Number 161. Table 21" x 6.5" with a reground top. No. 2 Morse spindle taper with speeds from 50-2400 r.p.m. run from the original three-phase motor and includes a high-quality Transwave one-phase to 3-phase 3.7KW converter. This is a very clean example of a robust, well-built and easy-to-use machine. All the sideways are good with smooth movements and pleasant to use. All spindle bearings and the drive gearbox are in good order.
Myford Super 7 lathe 3.5" x 19" gap-bed, backgeared and screwcutting and mounted on the maker's cabinet stand with chip tray and levelling blocks. In excellent condition, an ex-college machine and used by me occasionally for light model engineering. Complete with a 3-jaw chuck, the correct 6-inch half-depth body Burnerd 4-jaw chuck, tailstock chuck, faceplate, a new halogen work light and a chuck guard. 3-phase motor so ideal for conversion to infinitely-variable speed drive from a 1-phase to 3-phase inverter.
Quick-Step Milling Adapter (by John Payne Engineering). The Quick-Step is a powered spindle that can be mounted in the toolpost of most lathes with a centre height of at least 3.25".* High torque, reversible DC motor (runs on 240V or 110V mains), 9-speed drive from 100 to 4000 r.p.m., ER20 spindle/collet chuck system and a vertical slide accurate to 0.001" over 1.5" of travel. Very little used. £950. Also available: an 18" x 18" surface plate for £75
ANVIL - double-horned type. Please phone for more details. £75 or offers.
Rapidor Mechanical Hacksaw - this is a heavier-duty, 6-inch capacity version. Runs from a high-quality 1-phase to 3-phase converter by Transwave. Mounted on a wheeled trolly for ease of moving about. REDUCED to £375 -which includes the converter. Details of Rapidor saws here
South Bend Heavy 10 Toolroom Lathe. 5-inch centre height, 21 inches between centres, a 1-3/8" spindle bore, a 1-inch collet capacity and driven by a variable-speed 1-phase to 3-phase inverter that extends the range of the standard 12 spindle speeds. This is the genuine Toolroom version, mounted on the maker's rigid cast-iron underdrive stand and fitted with a taper turning, a screwcutting gearbox, power cross feed and a full collet set on an integrated mounting board.
Worden Tool & Cutter Grinder. Further developed by an experienced engineer to be a more effective unit - this example includes several very useful accessories. Single-phase motor and ready to use. £450
The bench press is £65
Henry Milnes Hand-operated planning machine. A beautiful, classic machine in perfectly original condition. Fully functional with the bed and slideway scraping marks visible. Details of Milnes planers can be found here.
Myford ML7 lathe 3.5" x 20" gap bed, backgeared and screwcutting. Bought new by my father in 1952 (Serial No K24436) and has been well-maintained over the years and kept in c/heated rooms - the paint finish is the original. Mounted on a Myford cabinet stand Single-phase 1/3 hp motor with a reversing switch.
Myford ML7 lathe serial no. K 64382.
A special and immaculate Boxford Model C lathe 4.5" x 24" backgeared and screwcutting. This lathe has been restored, over 400 hours, to the highest standards by an ex-Dean-Smith & Grace machine tool fitter with the bed and slideways have all hand scraped back into perfect alignment. Comes with a 3-jaw chuck, the correct half-depth body 6-inch 4-jaw chuck, a set of screwcutting changewheels including an inch-to-metric 127/100t transposing gear, genuine Boxford 4-way toolpost, thread-dial indicator faceplate, and a catchplate. The lathe’s first owner was Mr.
Sharp Universal Vertical and Horizontal Milling Machine. In perfect condition and full working order. Backgeared for gear-driven low speeds when horizontal milling and fitted with variable-speed drive using a 3-phase .55 kw motor controlled by a VFD (replacing the original .3KW single-phase motor which is included). This drive system has transformed the miller by making it bi-directional with speed controlled by just turning a knob. Table 16'' x 4.5'' with two T-slots able to be swung 25° in either direction from central.
Boley Model 3L or 4L backgeared and screwcutting lathe - for restoration. Long-term stored but with a mass of equipment including a set of screwcutting changewheels, spare chuck backplates - and everything shown in the photograph. Complete with a single-phase motor (untested), push-button starter and a "fast-and-loose" clutch-type countershaft. £295 or offers Full details of these lathes and their specification can be found here.
Rishton Vertical Milling Machine. UK-made, all-geared head, single-phase electrics. An ex-school machine with very little use, smooth running and in full working order. Includes a Clarkson Autolock collet chuck - and more than one set of both inch and metric collets - and a set of top-quality "Presto" brand cutters. The miller has been dismantled into large sections for transport and is all carefully packed in plastic boxes - hence it's possible to confirm the stated condition.
Emco FB2 Vertical Milling Machine. A well-made, compact and versatile machine with a table 25" x 6", longitudinal travel of 15 inches, cross travel of 5.5" and 14.5" of vertical travel on the head. The quill travel is 1.6 inches and the spindle bored with a No.2 Morse taper. Single-phase motor with six spindle speeds from 120 to 2000 r.p.m. Complete with comprehensive equipment including four genuine Emco accessories: a rotary table, a collet chuck with a set of collets, a boring head and machine vice.
Myford Super 7B with screwcutting gearbox, spindle clutch, quick-change toolpost and mounted on the maker's cabinet stand with levelling blocks and a deep chip tray. Previously owned by three model engineers in Banbury - who also had bigger lathes - so has had only light use. Hence, it's in good all-round condition with no obvious bed wear. Comes with a single-phase motor, push-button starter and a reversing switch, 3-jaw chuck, 4-jaw chuck, faceplate, catchplate, a precision keyless tailstock drill chuck, thread-dial indicator and a good selection of cutting tools.
Myford VM-B Vari-speed milling and drilling machine - a compact but versatile machine. Single-phase and complete with many useful accessories including a collet chuck with collets, the maker's swivel-base machine vice, a clamping set, tooling and the maker's operation manuals. In excellent original condition having had very little use by one private owner from new. Fully tested. Year of Manufacture 2000. Serial No 87136. Details of the Myford VM-B miller can be found here:
Simonet Precision Swiss Capstan Lathe. This is a high-quality, Swiss-made compact machine of Myford/Boxford size in full working order. It's driven by a 2-speed, reversible 3-phase motor (complete with a 3-phase variable-speed inverter) through an intermediate 2-speed gearbox with integral countershaft fitted with a 3-step pulley that gives 24 spindle speeds. It has very substantial headstock bearings (and a T-slot above the front bearing that allows the fitting of a tool slide).
Cowells 90ME Precision Miniature Lathe. The lathe is exceptionally well equipped with a range of genuine maker's accessories that include: a milling slide with machine vice, a Burnerd precision ring-scroll 3-jaw chuck, a Burnerd 4-jaw chuck, another 3-jaw chuck, a dividing attachment, fixed steady, travelling steady, a quick-change toolpost with 4 tool holders, a 4-way toolpost, a set of collets and a collet holder, a set of screwcutting changewheels, faceplate, two angle plates, four die holders, a rear toolpost for parting off, a tailstock chuck and revolving tailstock ce
Deckel FP1 Universal Precision Milling Machine equipped with the essential "all-angles" table. This is a very late-model example in splendid condition. The original unreliable drive system has been replaced by two infinitely variable speed, 3-phase motors with two suitable inverters to control them. One motor provides the spindle speeds (that now extend below and above the original 160 to 2000 r.p.m.) and the other the power feeds.
Pultra 1590 Precision Bench Lathe - this was the largest of the Pultra lathes made with a 90 mm (3.5") centre height and a 20 mm bore spindle. Complete with a screw-feed compound slide rest, 3-jaw chuck, a number of collets and the lever-action collet closer. Power is provided by a single-phase to 3-phase infinitely-variable speed inverter. £450 or offers. Full details of Pultra1590 lathes here
Lorch LLV precision plain turning lathe. 65 mm centre height and 225 mm between centres. Complete with a high-precision Burnerd 3-inch adjustable 3-jaw chuck. Also included is a compound slide rest (complete with the lathe from which it came) that could be adjusted to the Lorch bed and a choice of single-phase motors. £350 or offers. Details of Lorch LLV lathes here
For Sale: Amolco Vertical Milling Machine. A very tidy example mounted on a solid, inch-thick steel plate on top of a cabinet stand. This compact miller has seen little use in my ownership as it was always a little small for my needs. I've now a bigger miller, so this one is surplus to requirements. Comes with a single-phase motor, a Clarke table, a good-quality swivel-base machine vice, a Jacobs drill chuck and a little MT1 flycutter. Details of Amolco Millers here
Drummond Vintage Lathe circa 1910 - complete, original and in full working order. 3.5" x 15" gap-bed, backgeared and screwcutting. Mounted on the original maker's stand that has been motorised but retains the correct treadle-driven flywheel assembly. Complete with all the extensive tools and extras used by the last long-term owner.
REDUCED to just £375 as I desperately need the room.
Colchester Chipmaster Lathe. A very low-hours 5.5" x 23" lathe with speeds from 35 to 3000 r.p.m. Just fitted with a top-of-the-range Newton-Tesla inverter at a cost of £520. The lathe is in perfect working order, having only been used in a research and development department. I bought the lathe in 2017 - but it's been unused since 2019 due to back trouble.
An exceptionally fine, one-owner-from-new Myford ML7 lathe, 3.5" x 20 backgeared and screwcutting and in its original maker's finish. Very carefully used and fitted with an excellent range of accessories including a Cowells quick-feed capstan tailstock handle (and the standard screw-feed spindle), the correct half-depth body Burnerd 6-inch 4-jaw chuck, 7 "Norman Patent" quick-set toolposts, two Burnerd 3-jaw chucks, 3 sizes of tailstock chuck, tailstock rotating centre, graduated handle to the leadscrew end, tailstock sliding die holders, a handle to turn the spindle manual
Lodge & Shipley Lathe circa 1905. Fitted with a full screwcutting and feeds gearbox of the Norton "Quick-change" type, long-T-slotted saddle wings to act as a boring table. For its age this is an exceptionally heavily-built lathe with a deep bed casting, a 8-inch centre height and in fair condition. Has a 3-jaw chuck, 4-way toolpost, a micrometer-adjustable carriage stop and very strong tailstock. Power drive to the carriage - however I do not know if this works. Fitted with a 230-volt, single-phase 1 .hp.
Hommel UWG1 multi-function machine tool. It appears to be largely complete and with a number of accessories as shown in the photographs including a large number of screwcutting changewheels and collets. The only fault appears to be a broken bracket on the motor mount. More pictures available if requested. The machine is in the USA but I am happy to pack securely and ship worldwide at the buyer's cost. US$5000 or offers. Full details of the Hommel UWG1 can be found here
Colchester Bantam Lathe with a maximum capacity of 5.75" centre height and 23" between centres. Mounted on the maker's stand with a full-length splashback and fitted with a top-quality Newton-Tesla variable-speed drive system working from a household 1-phase supply.
This is a late-model Perris lathe - fitted with a proper Parvalux motor and very similar to the first Cowells lathe . There is a complete description of the Perris lathes on lathes.co.uk where you'll find the complete specification
Boxford ME10 single-phase imperial lathe 5" x 22". This late-model ME10 has the same mechanical specification as the AUD with a screwcutting gearbox and power sliding and surfacing feeds. The motor, though, is mounted behind the headstock using a very compact arrangement that allows (if required) the lathe to be bench-mounted.
For Sale: A beautiful Antique Weisser Model EE Lathe in full working order. With a centre height of around 6 inches, and talking perhaps 30 inches between centres, this backgeared and screwcutting Weisser lathe has been preserved in remarkably fine condition. Fitted with a Norton-type quick change gearbox (with an instant-release a dog clutch on the leadscrew, a detachable gap bed, power sliding and surfacing feeds, it's driven by its original remote countershaft and a single-phase motor.
MYFORD SUPER 7BPXF LATHE 3.5" x 19" gap-bed, backgeared and fitted with a screwcutting gearbox, power cross feed and coolant. Mounted on the maker's cabinet stand with levelling blocks, a deep chip tray, a full-length (maker's) splash back with a tool tray and cork mats. In superb order as rebuilt by the original Myford company to as-new condition.
Toyo ML-1 Miniature Precision Lathe 2" centre height and 10" between centres. 590mm long, 260mm wide and 175mm high (23.5" x 10.25" x 7"). I bought this lathe in the early 80’s to use for prototypes in my precision turned-parts company where we ran cam-operated auto lathes. I'm the only person to have operated the Toyo and, after the company closed in 1998, I brought it home for my clock-repairing hobby. It has been used for fewer than 100 hours since new.
Wabeco D6000 (German) lathe in hardly-used condition. Complete with the maker's stand, coolant tray and pump, a high-quality quick-change Swiss toolpost and tool holders, a Newall DP 700 2-axis DRO, a transposing changewheel set for generating metric pitches, precision keyless tailstock chuck, tailstock rotating centre and some tooling as shown in the photos. The spindle bore is a useful 30mm spindle bore and the lathe has a powerful, single-phase, 1.4 kW variable-speed drive. It's fair to say this lathe has far better quality control than lathes from Asia e.g.
Colchester Bantam Lathe 5.75" x 20" metric specification and mounted on the maker's stand with a stainless steel backsplash with 2 shelves. The lathe is still in the maker's paint finish, in very good condition and everything works as it should - and is a pleasure to use.
Myford ML10 lathe 3.5" x 13" backgeared and screwcutting. A one-owner from new machine and stored for some time unused. Fitted with a dog clutch, a graduated handle on the leadscrew end, a Myford milling slide, 3-jaw chuck, fixed steady, 4-way toolpost, rear toolpost, standard toolpost, tailstock drill chuck, tailstock sliding die holder, tailstock rotating centre, a full set of screwcutting changewheels, faceplate, spare chuck backplate, boring bar holder, Morse centers and a selection of cutting tools and Slocombe centres.
Warco "Super Min Lathe" with variable-speed drive and in hardly-used condition and with an excellent specification: mounted on a chip tray with a full-length splashback. 90 mm centre height and 350 mm between centres. Speeds 50 to 1100 r.p.m in the backgear-driven low-speed range and 100 to 2500 r.p.m in high with a digital rev counter. 3 Morse headstock taper, No. 2Morse tailstock. 3-jaw chuck, thread-dial indicator, 4-way toolpost, changewheels, centres, two tailstock chucks, tailstock rotating centre, sliding tailstock die holder, and turning tools etc.
Harrison M250 lathe 5.7" x 20" with a hardened bed and driven by a 1-phase to 3-phase converter.
Myford Super 7BPXF Long Bed Lathe - Serial No. SKL 126833 3.5" x 30" fitted with an Imperial screw-cutting gearbox with transposing changewheels for metric and BA pitches and power cross feed. Mounted on the maker's industrial cabinet stand, chip tray, raiser blocks and 1-phase electrics. In excellent condition with unworn bedways and in the maker's paint finish.
